Problem with 3rd Party SW installation
Old   January 2, 2011, 15:45
Default Problem with 3rd Party SW installation
Klaus
klausb will become famous soon enough
I keep getting an error when installing the OpenFoam from source. The foamInstallationTest shows the following error:
... Third party software
Software Version Location
gcc 4.4.5 /usr/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.23 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/simulation/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
I searched for a fix on the internet and found the following (useless) information:
In $WM_DIR/rules/linux64Gcc/c++, change LINKEXE to this:
LINKEXE = $(CC) $(c++FLAGS) -Xlinker --add-needed
Unfortunately this doesn't solve the problem.
How can I fix the problem?
klausb is offline   Reply With Quote
Old   January 2, 2011, 18:14
Retired Super Moderator
Bruno Santos
Greetings Klaus and welcome back to the forum! I just saw that the last time you posted was in 2007!
OK, you gave very little information for us to infer what was the problem. The actual error isn't related to Third Party software but in fact due to OpenFOAM itself not compiling with success.
I can only assume that you are trying to install OpenFOAM 1.7.1 in Fedora 13 or 14 x86_64. Under this assumption, I suggest that you read these two threads:
I suggest reading them thoroughly because multiple problems and respective solutions are posted in those threads!
If you still have problems compiling OpenFOAM, please run Allwmake in OpenFOAM's project folder like this:
./Allwmake > make.log 2>&1
tar -czf make.log.tar.gz make.log
Then attach the make.log.tar.gz file to your next post!
Best regards,
Bruno
Old   January 4, 2011, 03:43
Default It finally worked!
Klaus
after installing some additional packages mentioned in a number of posts on the web, the installation worked.
Anyway thank you for the help offered!
OpenFoam-1.6.x installation problem vsnprasad27 OpenFOAM Installation 1 August 21, 2010 04:35
Installation paraFoam - still problem nhl OpenFOAM Installation 7 June 22, 2010 09:22
[Other] Importing regions from 3rd party meshing programms suitup OpenFOAM Meshing & Mesh Conversion 1 November 10, 2009 09:40
3rd party visualization software urgent Siemens 0 March 6, 2007 03:55
STAR-CD installation Problem Zaheer Abbas CFX 0 October 24, 2005 23:28
