float or scalar for runTime.tinename() ??
Old   February 2, 2011, 13:26
Default float or scalar for runTime.tinename() ??
Fábio César Canesin
Canesin is on a distinguished road
I had look around but I'm not finding a method to call to provide the time the simulation is on.. I wan't to make a change when time = changetime..
I have tried to do casting like:
float(runTime.timeName()) but it do not work.... I'm starting to believe I will have to implement the casting..
Canesin is offline   Reply With Quote
Old   February 2, 2011, 14:12
Retired Super Moderator
Bruno Santos
Hi Fábio,
Type casting only works when the variables are similar, for example between pointers and between double/int/float and so on. To convert a string to float, you can use atof.
But I think that runTime.value() will get you the value already in scalar (float or double) format, without the need to convert the value.
Best regards,
Bruno
Old   February 2, 2011, 15:36
Fábio César Canesin
LOL ...
Thanks Bruno, I had looked at the doxygen but the method "value()" was not there, I believe it's because it is from inheritance..
Old   February 2, 2011, 17:13
Bruno Santos
You should always check the fine print
Solving for an additional species CO in coalChemistryFoam N. A. OpenFOAM Programming & Development 3 February 18, 2019 05:58
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
OpenFOAM and gpgpu dewald OpenFOAM 37 August 29, 2014 09:32
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
to correct me an udf program farida hamadi FLUENT 0 December 18, 2004 05:54
