fuction for ddt(n) which n is normal surface vector |
April 11, 2011, 06:34 |
Mohammad.R.Shetab
Dear Foamers
I'm writing an acoustic code for dynamic mesh case in a centrifugal fan. I use turbDyMFoam with movingWallVelocity BC at blades. In one of the terms of this code, ddt(n) is needed, witch n is the normal vector of the blade surfaces that move around. I know the functions for normal vector of the patches but for its time derivative I don't know how to calculate them. Another question is, Is there any function that could calculate velocity of the faces of the blade (which use dynamic mesh dict and movingWallvelocity) ?! Thank you Mohammadreza Shetab |
October 5, 2016, 08:14 |
Sergej
Rep Power: 10 |
Hello Foamers and Mohammadreza,
I have the same problem now and read many topics here in cfd-online.com, but did not found any solution. I hope for a hint, because my tryings were not successfully. So how to calculate the surface normal velocity of a free design surface? For example on the rotor in the picture which is uploaded here, the rotation vectors are shown. So the normal surface velocity on the x-y plane must be zero, because there is no moving in the direction of the surface normal. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
out normal vector | ztdep | Main CFD Forum | 0 | September 14, 2008 08:08 |
Normal Vector on Curved Surfaces | Karl | FLUENT | 0 | July 2, 2001 04:35 |
