Radiation with Boussinesq approximation
Old   June 7, 2011, 08:45
Default Radiation with Boussinesq approximation
ayoros is on a distinguished road
Hi everyone !
I would like to perform computations based on buoyantBoussinesqSimpleFoam and including radiation.
I took a look at the buoyantSimpleRadiationFoam to check the radiation part in the energy equation.
My problem is I don't see how to adapt the radiation contribution in the energy equation to the temperature equation of buoyantBoussinesqSimpleFoam.
Did anyone already try to do so ? Or can anyone give me a hint on this ?
thanks in advance.
Fabien
ayoros is offline   Reply With Quote
Old   January 22, 2013, 06:46
Markus Trompa
MisterX is on a distinguished road
Hello ayoros,
I am working on quite the same problem as you did. I want to implement radiation(only with view factors) in buoyantBoussinesqPimpleFoam but don't know exactly how to implement radiation terms in TEqn. Did you solve this problem?
I am wondering because the calculation of Sh() for view factor is zero, do I have to handle with this stuff or can I use the normal bBPF solver?
I would appreciate it if you could share your experience with me on this topic.
Thanks in advance.
Greetings
Markus
MisterX is offline   Reply With Quote
Old   September 8, 2013, 15:19
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Does anybody has any solution for this?
Same problem here !
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 12:21
Boussinesq approximation, help please! engahmed FLUENT 0 May 20, 2010 11:25
Question on boussinesq approximation panos_metal FLUENT 1 January 11, 2010 11:18
boussinesq approximation jamal FLUENT 2 March 25, 2008 08:57
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 09:24
