June 30, 2011, 04:30 |
blockMesh and surface mesh
Rep Power: 16 |
I have a surface mesh, or rather grid points on a curved surface. Now I want to build a grid in blockMesh at the same exact locations I have. Is there any way to specify each and every grid point I want on a surface and tell blockMesh to construct a grid based on those points?
Its like following the bottom to top approach. I have surface mesh and I need to construct a volume mesh in blockMesh from the available surface mesh. |
July 3, 2011, 01:26 |
Alan Russell
Rep Power: 16 |
I think you need to use snappyHexMesh. Basically, you build a cube in blockMesh around your surface with the surface slicing through the cube. Then, you use snappyHexMesh to generate a mesh that conforms to the surface and meshes the volume from your surface to the top of the cube. The motorBike tutorial is a good model to follow. I don't think you can mesh an irregular surface in blockMesh, but snappy does it quite well.
Alan |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] problemes modelling surfaces with snappyhexmesh | gija79 | OpenFOAM Meshing & Mesh Conversion | 5 | June 30, 2010 13:50 |
[snappyHexMesh] Problem with snappyHex: no body | lovecraft22 | OpenFOAM Meshing & Mesh Conversion | 5 | June 23, 2010 11:05 |
[mesh manipulation] TranformPoints gives skewed mesh Possible Bug | andersking | OpenFOAM Meshing & Mesh Conversion | 3 | March 25, 2008 21:33 |
[blockMesh] BlockMesh for a rectangular domain with curved bottom surface | segersson | OpenFOAM Meshing & Mesh Conversion | 0 | April 17, 2006 14:11 |
