July 2, 2013, 10:00 |
StreamFunction
Luis Batista
Hello Forum,
I am doing an analysis to a cavity flow using SimpleFoam.... Is there any known issue/error with the OF(2.1.2) function StreamFunction ? Apparently, I am having proper results within my vorticity vector field but when I plot the point field resulting from the streamFunction in Paraview, it seems that the results are 10 times smaller....I also see that the units of the streamfunction scalar field are L3 T-1. How are these units being derived? Regards, Luis |
July 7, 2013, 05:57 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Luis,
Can you provide a simple test case? Best regards, Bruno
August 19, 2013, 13:37 |
Christiane Lechner
Dear Bruno and Luis,
I find the same with version 1.6-ext: the stream function seems to be too small by a factor of 10 and has dimensions length^3/time. I attach a case of a linear shear flow, U = (y/H)*V, with H the height of the domain, and V the velocity at the upper boundary. The stream function should be: \Psi = 0.5*((y/H)^2 -1)*V*H best regards, Christiane |
August 20, 2013, 05:34 |
Christiane Lechner
the factor 0.1 seems to stem from the cell width in the empty direction, which is \Delta z = 0.1 in the above example. Reducing \Delta z to 0.01 also reduces the streamFunction by another factor of 10. So it seems, that the streamFunction utility computes \Psi*\Delta z, not \Psi. This would also explain the dimensions length^3/time. Do you agree? best regards, Christiane |
August 21, 2013, 09:32 |
Bruno Santos
Rep Power: 128 |
Greetings Christiane,
Many thanks for the test case, but I haven't yet managed to look into it. But I've taken a quick look into the source code of "streamFunction" on both 2.2.x and 1.6-ext:
Another indication is that it doesn't seem to work for 3D simulations, because it assumes that Z is the empty orientation. I'll try to look at the test case later today. Best regards, Bruno
August 22, 2013, 12:28 |
Christiane Lechner
Hi Bruno,
yes, the face flux field phi is phi = U_f & S_f, with S_f the area of the face. For the computation of the stream function U_f & S_f/\Delta z would be needed instead. best regards, Christiane |
August 22, 2013, 12:59 |
Bruno Santos
Rep Power: 128 |
Hi Christiane,
Of course! Why didn't I visualize that... the face area still depends on Z, even though the flow is only over X-Y. OK, then there are 2 immediate solutions:
Bruno
August 26, 2013, 04:29 |
Christiane Lechner
Hi Bruno,
thanks! I requested bug fixes at both sites: http://www.openfoam.org/mantisbt/view.php?id=976 http://sourceforge.net/apps/mantisbt...iew.php?id=185 best regards, Christiane |
January 21, 2020, 08:54 |
Nima Samkhaniani
Rep Power: 24 |
bug still is available in OpenFOAM_4ext but solved in foundation version.
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
August 27, 2021, 13:07 |
A. Min
Rep Power: 12 |
Hi all
Does streamFunction work on openFoam-v7? |
streamfunction |
problem of streamFunction in buoyantBoussinesqSimpleFoam | jignesh_thaker2007 | OpenFOAM | 5 | July 9, 2019 05:58 |
Computing StreamFunction | Tempest | OpenFOAM Post-Processing | 0 | January 7, 2017 06:17 |
sampleDict for streamFunction | srivatta | OpenFOAM Post-Processing | 3 | November 30, 2014 09:53 |
UDF for streamfunction | nisha | Fluent UDF and Scheme Programming | 0 | September 15, 2009 06:55 |
streamfunction from u and v on a coarse mesh | ryoga | Main CFD Forum | 0 | February 1, 2002 18:20 |
