[General] Problem in using mpiexec to run paraview on the Window 7?
Old   October 30, 2013, 03:20
Question Problem in using mpiexec to run paraview on the Window 7?
Sia
YaGao
Sia is on a distinguished road
hi, my English is not good, but i will try my best to describe my question.
Here is the problem:
I'm using ParaView4.0.1 - 32bit on windows 7.
I used the command "mpiexec.exe -np 2 -host localhost pvserver.exe", two pvserver processes was started and worked fine.
But if I want to start 4 pvserver processes , 2 on computer1 and 2 on computer2, what command should I use?
Sia is offline   Reply With Quote
Old   November 1, 2013, 18:23
Retired Super Moderator
Bruno Santos
Greetings Sia and welcome to the forum!
I see that you've read this post: http://www.cfd-online.com/Forums/par...tml#post457840 - post #4
Since ParaView 4.0.1 on Windows uses Open-MPI, therefore these instructions should work: http://www.open-mpi.org/faq/?categor...imple-spmd-run
Best regards,
Bruno
distributing server, mpich2, paraview, windows 7
[OpenFOAM] Problem on multicore in running paraview foamF ParaView 5 April 23, 2019 15:57
[General] PBS script to run ParaView in parallel on remote server hconel ParaView 0 December 25, 2018 02:38
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[OpenFOAM.org] ParaView intsllation problem Srinivasa Rao OpenFOAM Installation 6 August 25, 2015 06:27
window management problem. chidu CFX 0 March 7, 2005 11:00
