[OpenFOAM] How to visualize cellset region in OF?
Like Tree15Likes
  • 8 Post By wyldckat
  • 1 Post By CjjJoy
  • 6 Post By wyldckat
Old   March 16, 2014, 19:19
Question How to visualize cellset region in OF?
jingjing cao
CjjJoy is on a distinguished road
Hello,Foamers,
I'm now using the snappyHexMesh in OF2.3.0.In the checkMesh log, there shows:
<<writing region information to "0.3/cellToRegion"
<<writing region 0 with 1437789 cells to cellset region0
<<writing region 1 with 1 cells to cellset region1
(folder 0.3 is the mesh with the layer added mesh.)There is a cellToRegion file in the 0.3 fold.
could anyone tell me how to visualize these cellset region?
Thank you so much!
CjjJoy is offline   Reply With Quote
Old   March 23, 2014, 16:47
Retired Super Moderator
Bruno Santos
Greetings CjjJoy,
Either use foamToVTK:
foamToVTK -cellSet region0
where "region0" is the name of the desired cellSet. Then open the respective file located somewhere inside the folder "VTK".
Or use the "Include sets" option and select the desired sets from the "Mesh parts", as partially shown in the attached image.
Best regards,
Bruno
File Type: jpg Screenshot from 2014-03-23 21:45:57.jpg (37.2 KB, 1124 views)
saadat66, Rojj, t.oliveira and 5 others like this.
Old   March 25, 2014, 13:50
jingjing cao
Thank you so much. Problem is solved now.
Originally Posted by wyldckat View Post
Greetings CjjJoy,
Best regards,
Bruno
SHANRU likes this.
Old   December 20, 2016, 22:42
Francis
afrotimy is on a distinguished road
Greetings CjjJoy,
Best regards,
Bruno
Please what version of Paraview has this function ? I noticed that this function is not available in all version.
afrotimy is offline   Reply With Quote
Old   December 22, 2016, 10:10
Bruno Santos
Quick answer: If you're using the native/built-in reader that ParaView has got (opens with the file extension ".foam"), it does not have this feature. It only works with 'zones', not with 'sets'.
If you use the reader that OpenFOAM or foam-extend build for ParaView (opens with file extension ".OpenFOAM"), then you should see that option since at least OpenFOAM 1.5 and the same for the respective foam-extend fork (back then named OpenFOAM 1.5-dev).
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
