[General] Contour mage defect
Old   March 20, 2014, 21:10
Default Contour mage defect
Chris
chrisjj is on a distinguished road
Can anyone suggest a remedy for this defect appearing with filter Contour and Opacity <1 ?
This is using the demo of http://www.youtube.com/watch?v=UjoSvWdxlTA. Running V4.1.0 64-bit on Win7 EDIT: and Integrated Intel® HD Graphics 2500/4000.
Thanks.
chrisjj is offline   Reply With Quote
Old   March 23, 2014, 14:08
Retired Super Moderator
Bruno Santos
Greetings Chris and welcome to the forum!
Looks like a problem with the graphics card drivers. Make sure you update them.
On the other hand, if you're using an Intel graphics processor... there are some GPU models that have some weird flaws that ParaView is not able to handle, simply because the drivers do not properly identify which features are not working as intended.
Such an example occurs with the Intel GMA 4500MHD, as described here: http://www.cfd-online.com/Forums/par...tml#post477703 post #16
Best regards,
Bruno
Old   March 23, 2014, 19:09
Chris
Thanks Bruno.
Have done
I am - Integrated Intel® HD Graphics 2500/4000.
Thanks. I see "... does require certain OpenGL extensions that may not exist on certain older cards and/or drivers." and because this card is a Dell model new last year, I guess the same perhaps applies to some newer too.
So, no joy for me!
Thanks Bruno.
Old   March 26, 2014, 16:36
Bruno Santos
Hi Chris,
You're welcome!
And from what I could find the other day, with any luck, the next version of ParaView might have this issue either fixed or at least will tell the user about why it's not working: http://www.vtk.org/Wiki/VTK/OpenGL_Errors
Best regards,
Bruno
Old   March 26, 2014, 17:11
Chris
Good news. Thanks again!
generating 2d-planar contour plots from a contour plot on a curved surface alinik CFX 3 May 21, 2016 06:17
[snappyHexMesh] Advice on how to keep cells inside a closed contour CrisMoreira OpenFOAM Meshing & Mesh Conversion 7 July 23, 2015 12:16
[GAMBIT] Plotting/Meshing a Contour Map (3D hill) VU_Engineer ANSYS Meshing & Geometry 6 January 28, 2014 06:59
Showing contour height flow_CH Tecplot 1 July 22, 2013 11:08
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
