[General] Paraview: plot over a certain value and add axis
Old   May 13, 2014, 20:53
Default Paraview: plot over a certain value and add axis
Kan
nwpukaka is on a distinguished road
Is there any filter to plot over a certain value in Paraview? I want to connect the points having the same value, I'm not sure if there is any option in Paraview.
Also, how can add axis with a certain value on it?
Thanks in advance
Kan
nwpukaka is offline   Reply With Quote
Old   May 16, 2014, 16:01
Retired Super Moderator
Bruno Santos
Greetings Kan,
The "Threshold" filter helps isolate data points or cells/faces that are within a certain interval of values.
Then you can apply the "Plot Data" filter to plot those values.
In the Display section/tab for this item (e.g. "PlotData1"), you can choose the data fields you want to plot.
Best regards,
Bruno
