[General] Mass flow rate over time
Like Tree3Likes
  • 1 Post By vikingd
  • 1 Post By foamiste
  • 1 Post By qutadah.r
Old   December 4, 2019, 07:15
Exclamation Mass flow rate over time
Viking
vikingd is on a distinguished road
Hello all,
Can any of you please tell me how to plot mass flow rate through a surface over time? I use MESHFREE for my simulation. Its based on the finite pointset method.
since im new to Paraview a step by step solution would be very appreciated.
Thank you all
Stefanie.S.W. likes this.
vikingd is offline   Reply With Quote
Old   January 10, 2020, 05:06
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
Hello all,
I would like to do the same analysis.
So far I tired on a slice:
Filter "Calculator" -> Velocity of phase in normal direction to slice * phase fraction
When chosen point data the filter "Integrate Variables" is possible. It seems that it integrates over time and surface, which leads to a total volume over total time. Unfortunately I could not find a good documentation on this.
In addition to trying the IntegrateVariables-Filter I plotted the data from the calculator over time (for every second) and took it times the surface area of the slice. When But that is not very accurate.
My case is a multiphase simulation in OpenFoam and I use a slice (Filter) as surface to monitor the mass flow.
Do you have another approach or do you know a documentary to the filters in paraview?
Thank you in advance!
Stefanie.S.W. is offline   Reply With Quote
Old   February 20, 2020, 09:17
Viking
The following method works for me.
Using a slice or clip filter, extract the surface where you wish to calculate mass flow on. Apple the following filters:
-->Generate surface normals
-->Calculator filter ( Density*(Velocity.Normals) )
-->Integrate variables
-->Plot data over time
Hope this helps.
Old   February 16, 2022, 12:42
qutadah
qutadah.r is on a distinguished road
Originally Posted by Stefanie.S.W. View Post
Hello all,
did this work for you in the end? I am also doing multiphase simulation, but why are you multiplying with phase fraction, density_phase* Velocity_phase on a surface should do it right? I am also trying to calculate mass flow rate over a surface but I do not get any results.... I would appreciate if you share your experience, thanks!
qutadah.r is offline   Reply With Quote
Old   February 23, 2022, 03:30
Arrow How to Calculate the FlowRate and Plot it Over Time in ParaView
Asmaa
foamiste is on a distinguished road
This may help you!
https://youtu.be/vgFL8kv320w
qutadah.r likes this.
foamiste is offline   Reply With Quote
Old   February 23, 2022, 05:26
Default Thanks!
qutadah
Originally Posted by foamiste View Post
This may help you!
Thank you! I watch your videos regularly btw, keep up the nice work !
Best Regards,
Qutadah
foamiste likes this.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 41 August 23, 2023 02:48
Epyc 7551 vs 6850K; Ansys Mechanical Bench Duke711 Hardware 24 March 26, 2020 10:16
Auto saving of mass flow rate or discharge with time step Tanjina FLUENT 2 December 1, 2014 14:15
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
