[OpenFOAM] How to annotate functionObjects in ParaView? |
September 10, 2020, 08:42 |
Tobias Kienzler
Rep Power: 6 |
Greetings!
I've put Code:
functions { forces_impeller { type forces; libs ("libforces.so"); writeControl writeTime; writeFiels no; patches (impeller); rho rhoInf; rhoInf 1e3; CofR (0 0 0); } } Can anyone help me? Best regards Tobias |
September 14, 2020, 09:12 |
Jan
Rep Power: 19 |
Hi Tobias,
the forces functionObject gernerates time series data of the pressure, viscouse and prorous forces. The data is stored in postProcessing/../forces_impeller.dat (in your case) text files. The output format is an OpenFOAM specific format using brackets to enclose the forces and moments. To plot these data in ParaView you first need to convert the format it in order to ensure ParaView understands correctly. I think easiest is to convert to comma separated (csv) format and remove the comments. Using bash this could be done e.g.: Code:
tail +4 forces_impeller.dat |tr -d '()' |awk 'BEGIN {OFS=","} {$1=$1}1' > forces_impeller.csv Hope this helps, Jan |
September 23, 2020, 09:39 |
Tobias Kienzler
Rep Power: 6 |
Hi Jan, I'll give it a shot, thanks! I wish there were a way to directly read the existing data into ParaView though...
September 23, 2020, 10:22 |
Jan
Rep Power: 19 |
Hi Tobias,
just to be curious, is it really necessary to plot the time series in paraview? There are a lot good tools to plot time series, gnuplot etc... However, if you are a little bit familiar with python, you may also create a python marco, which does the file conversion. Then you do not need to do this every time in the bash Best, Jan |
annotation, openfoam, paraview, uniform constant |
How to annotate functionObjects in ParaView? | zommuter | OpenFOAM Post-Processing | 1 | September 10, 2020 08:44 |
[OpenFOAM] Paraview 5.0.1: no option to scale or shift Annotate Time filter | adhiraj | ParaView | 2 | March 10, 2020 10:38 |
[OpenFOAM] Paraview does not display objects (functionObjects) | Proportion | ParaView | 0 | October 16, 2017 08:26 |
[OpenFOAM] Paraview annotate time | Aravind_Krish | ParaView | 4 | August 19, 2016 08:05 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
