[OpenFOAM] Visualisation of components of a vectorField
Like Tree1Likes
  • 1 Post By theof
Old   May 29, 2006, 09:23
Default Visualisation of components of a vectorField
Nico Petry
nico is on a distinguished road
Hi!
I define a plane in my geometry and want to visualize the velocity with arrows in this plane. No problem so far. But I dont want to see the component of the velocity normal to the plane. Is it possible to show only let me say the x and y component and to remove the z component?
Thanks
nico is offline   Reply With Quote
Old   May 29, 2006, 09:49
Default You can do it easily with para
theof
You can do it easily with paraview. Select your cutting plane and apply the filter Surface Vector, selecting the option Parallel. Then apply the filter Glyph and set as input the Surface Vector. You should then see only the parallel component of your vector field on the cutting plane.
theofane
faiazk likes this.
Old   September 18, 2021, 23:42
A. Min
alimea is on a distinguished road
theofane
Hi
Is it possible to do a sample (using the sample function object) and calculate the velocity components on that surface?
alimea is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
Accessing velocity components and gradient of velcoity components vivekgnhtr OpenFOAM Programming & Development 3 June 27, 2022 02:39
Question on the sequence of grad(U) components ripperjack OpenFOAM Post-Processing 1 September 18, 2018 12:19
power of vectorField matthias OpenFOAM Programming & Development 0 August 19, 2014 08:52
Transient Statistics for turbo components Suzzn CFX 5 May 4, 2010 09:56
