[OpenFOAM] How to open OF files in Paraview 3.6.1?
Old   November 28, 2009, 17:59
Default How to open OF files in Paraview 3.6.1?
Xye
Xye is on a distinguished road
Now that i have successfully installed OpenFOAM i was running through the tutorials when i came across a problem.
When It comes to the third step of the tutorial and you have to type in paraFOAM it gives a list of options: What do i want to open the Data with?
I tried opening with the OpenFOAM reader but Paraview instantly shuts and in the terminal it says about Qt has caught an exception thrown from an event handler.......
I Also tried the command foamToVTK (i think it was) then tried to open paraview and selected the option of reading straight from the raw data but that shows nothing at all and gives several errors in the terminal.
Can someone help?
Xye is offline   Reply With Quote
Old   December 5, 2009, 09:36
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I am not sure about paraFoam, possibly the reader hasn't been compiled but
Using foamToVTK:
In the case directory, execute: 'foamToVTK'
This creates a 'VTK' directory in your case directory.
This 'VTK' directory contains the VTK version of your case and your time directories with results.
So start paraview by typing 'paraview'.
Then in paraview, go 'File' and 'Open' and then browse into the 'VTK' directory and open the '*.vtk' file.
Then click 'Apply' in paraview and you will see your case.
You can then post-process and visualise your results.
Hope it helps,
Philip
bigphil is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
