[OpenFOAM] paraview 3.10.1 reading decomposed data
Like Tree1Likes
  • 1 Post By wyldckat
Old   September 13, 2011, 07:39
Default paraview 3.10.1 reading decomposed data
Stefan
preibie is on a distinguished road
Hallo,
I want to read a decomposed case with paraview. But in the new version 3.10.1 I doesn't have the choice to read a decomposed or reconstructed file.
Have somebody an Idea
Thanks
preibie is offline   Reply With Quote
Old   September 13, 2011, 08:27
Retired Super Moderator
Bruno Santos
Greetings Stefan,
If you are running ParaView with OpenFOAM 2.0.0/1/x, then run it like this:
paraFoam -builtin
This will make it use the internal reader for OpenFOAM cases, which allows you to open a decomposed case without the need for MPI.
Nonetheless, the internal reader in ParaView 3.10.1 sometimes fails to open certain cases/results that were executed with OpenFOAM 2.0.
If these fail, then the next step would be to run:
reconstructPar
for the decomposed case to be reconstructed.
If you still want to try and open the case with ParaView in parallel mode, see your other thread: http://www.cfd-online.com/Forums/ope...-parallel.html - I'll answer you there shortly!
Best regards,
Bruno
amuzeshi likes this.
What‘s wrong with my cvg case? WUJT CONVERGE 8 October 13, 2017 12:19
[General] Reading array in data structure in paraview with vtkMultiBlock gafxian87 ParaView 0 September 14, 2017 07:47
execFlowFunctionObjects - unknown field problem Toorop OpenFOAM Post-Processing 16 March 14, 2016 03:25
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
