how to use my own ground?
Old   September 14, 2001, 23:43
Default how to use my own ground?
zhengenhui
dear everyone:
I am a freshman of PHOENICS, and i want to simulate the flow behavior in the riser of CFB.
After finishing the settings on the VR-Editor , i edit my own ground.f file, what should i do in the next step and how(compile or link)?
Look forword to your help!
oh,my god! today is saturday.
zhengenhui
Old   September 19, 2001, 14:20
Default Re: how to use my own ground?
Kike
Dear Zheng
When you edit your Q1 file by means the VR-Editor you need to exit (saving changes) to achieve the data file "eardat".
The option BUILD -> EARTH will automatically execute your local "bldear.bat" file. "local" means this batch file which is into your actual working directory.
Modify your batch file bldear.bat (or copy it from d_earth\d_win32 for windows 9x, ME, NT, 2000) to include your "personal" ground file instead of the default option.
After that, each time you build your "earexe" you will have your personal version ready to run (if everything have been well done inside it).
The next step is to run it by: OPTIONS -> RUN VERSION -> EARTH -> PRIVATE and clicking on right hand column EARTH button.
Regards
Kike
Old   September 26, 2001, 07:45
dhandapani
hai,
after setting dates,
1. save the data in vr editor.
2. open earth option for solution
3 . for 3d results.open photon, go to file option.and press phi, xyz file and accept.
Questions about GROUND mahe Phoenics 4 August 7, 2008 10:06
GROUND LITTLE HELP STK Phoenics 0 February 7, 2004 12:00
ground mesh of a car Juan Manuel Main CFD Forum 0 August 31, 2003 19:30
Private Ground Mohamed Ouzzane Phoenics 4 June 10, 2002 11:11
How to use q1 and ground file? zheh Phoenics 5 September 9, 2001 05:01
