February 3, 2015, 09:53 |
Pointwise export to CGNS
Jack B.
I'm working on ANSYS CFX with imported CGNS files created by Pointwise. Recently, I've upgraded Pointwise to version 17.2R2. When trying to import CGNS files into CFX-Pre, I've received the following error messege: "Unable to import mesh: can't open XXXXX for reading. Reason: array size exceeds that for a 32-bit integer." I suspect this is connected to a new feature from V17.2R1 - CAE export format upgrades to CGNS v3.1.4. What are my options? Thanks. |
February 4, 2015, 12:43 |
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
My first suggestion would be to switch your solver to Ansys CFX (menu CAE/Select Solver...) and then export using menu File/Export/CAE....
If that won't work for you, we can discuss other options. |
August 9, 2018, 08:02 |
Same Problem
Rep Power: 10 |
the same problem as mentioned in the thread just occurred when I tried to import a *.cgns file to Ansys CFX. The solver setting is set to Ansys CFX.
Looking forward to other suggestions regarding the problem? |
September 5, 2018, 11:31 |
Zach Davis
Make sure you have both the CAE Solver in Pointwise set to ANSYS CFX and that you're using the CAE... option from the Export sub-menu of the File menu. The grid files that Pointwise outputs will be in CFX's native grid format, and you should not have CGNS files.
[Commercial meshers] Pointwise grid export to Openfoam | Eren10 | OpenFOAM Meshing & Mesh Conversion | 15 | May 30, 2019 17:10 |
CGNS to .su2 mesh (multi zone, pointwise assistance?) | jacobH | SU2 | 4 | September 9, 2014 04:40 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
CGNS problematic import in Pointwise | S.Kontogiannis | Pointwise & Gridgen | 8 | April 17, 2014 07:28 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
