Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
airfoil 2D mesh with Gridgen
Old   November 23, 2009, 10:30
Default airfoil 2D mesh with Gridgen
famarcfd is on a distinguished road
Hi all!
I've to generate a structured mesh with Gridgen around a nose cambered airfoil (shape similar to a turbomachinary blade).I've already done it with extrusion method getting a C shape mesh.For futher applications I need to generate an O or H mesh as well.How should I proceed?
Can anyone help me?
Thanks in advance!
famarcfd is offline   Reply With Quote
Old   November 24, 2009, 07:26
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
Draw the airfoil in a rectangular region, then seperate the region into several block. generate structured grid in these region.
Hope this wil help you
ztdep is offline   Reply With Quote
Old   November 24, 2009, 17:00
Thanks for your advice
Old   January 28, 2010, 10:06
Default 2D C-H airfoil with Gridgen
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
I am trying to generate a 2D mesh around symmetrical airfoils. C type upstream and H type downstream of the airfoil. My problem is with the C type subdomain.
I want to do it by extruding an edge (the airfoil), with X-symmetry for boundary condition, up to 30 chord lengths away. My most importante concern will be the orthogonality at the airfoil's wall, and how to keep it as gridlines travel away.
My best shot up to this point has been to creat a "raw" mesh and run the structured solver on it. And this is what's giving me the big headache I'm attaching a screen capture of my "raw" grid to show what's my starting point for the smoothing process.
Thanx in advance!
aerospain is offline   Reply With Quote
Old   January 30, 2010, 16:56
John Chawner
jchawner is on a distinguished road
Carlos:
If I understand your topology correctly, you want to create a grid with C topology around an airfoil. The topology includes, for example, lines that pass from the downstream boundary, move upstream over the top of the airfoil, around the leading edge, downstream along the bottom of the airfoil and straight out the downstream boundary.
You could generate this topology completely using Gridgen's extrusion technique without having to resort to the elliptic solver at all. Your initial boundary would be the wake connector, the connector on the upper surface of the airfoil, the connector on the lower surface of the airfoil and the wake connector (the same one as the first). The grid would be orthogonal to the airfoil surface and the wake.
Does this work for you?
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   March 7, 2022, 17:28
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
Old   September 2, 2022, 04:15
Default Re: H grid airfoil 2D
mehulsasvadiya1996@gmail.'s Avatar
Mehulbhai Sasvadiya
mehulsasvadiya1996@gmail. is on a distinguished road
Is there any other way to generate H airfoil automatically?
thanks in advanced
mehulsasvadiya1996@gmail. is offline   Reply With Quote
airfoil, gridgen, h mesh, o mesh
[blockMesh] 2D airfoil optimisation the mesh martapajon OpenFOAM Meshing & Mesh Conversion 9 May 14, 2011 13:33
Negative Volume in Mesh by Gridgen James FLUENT 5 February 3, 2010 07:34
Airfoil Mesh for DES Analysis - y+ Value asd Main CFD Forum 1 May 3, 2007 10:13
airfoil, mesh spacing problem, CFX-ICEM Santiago Orrego. CFX 3 January 14, 2007 18:19
