PSTT File
Old   November 3, 2000, 15:16
Default PSTT File
Yuan Shen
I am a beginner with STAR-CD. When running tutorial 13, I followed the instructions step by step, however, I can not get the tut.pstt. What I can get is only tut.pst. Could you pls tell me the reason?
Thank you very much!
Old   November 4, 2000, 05:31
Default Re: PSTT File
Ahmed Hassaneen
Hi Yuan, Tutorial 13 !!!!!!!!. Tell me first how you run the tutorial and have you got the star solver working? if yes are running the solver from PROSTAR environment or outside it??
Old   November 5, 2000, 15:28
Yuan Shen
Hi, Ahmed:
Thank you very much for your help!
I followed the intructions exactly. First, after setting the event number, I load the geomtrical data and boundary data. Second step is to define boundaries and events. After that, I verified the events and they are OK since my mesh animation is perfect. Finally, I run "pmovlink" and "starlink" and get the executable file "star". After running "star", what I get is "tut.pst" instead of "tut.pstt". However, on the tutorial, it is said that "tut.pstt" should be generated at this step.
BTW, I ran the solver out of the PROSTAR enviroment as mentioned on the tutorial.
Thanks again and look forward to your further response.
Old   November 6, 2000, 08:52
J. Y. Luo
Hi, Shenyuan,
The output to .pstt file is controlled by two prostar commands:
1. frequency control
LSTEP 1 360 CONS 1.6666E-4 N 0 5
The last integer 5 indicates that the results will be saved every 5 time steps.
2. output control (what to save)
CPOST Y Y N Y Y Y Y Y Y N Y
(u v w p k e t vis den)
Can you first check what happens when these commands are input in PROSTAR (there are part of prep.inp file).
If everything is OK, these information would also be in tut.run file:
| MAX. NO. OF TIME STEPS ...... => 360 |
| STARTING LOAD STEP NUMBER ... => 1 |
| NUMBER OF TIME STEPS ...... => 360 |
| TIME STEP SIZE ............ => DT = 1.666600E-04 s |
| RAMPING ................... => OFF |
| POST DATA FREQUENCY ....... => 5 |
| CELL DATA SELECTED....... => U, V, P, TE, ED,TVI, T,DEN, H, |
| => INTAKE |
| => EXHAUST |
| PRINT DATA FREQUENCY ...... => 0 |
| NO. OF FLUID MATERIALS ...... => 3 |
Old   November 6, 2000, 13:28
Yuan Shen
Old   November 6, 2000, 13:36
Yuan Shen
First of all, Thank you very much for your help. After checking the frequence control and output control, I found that what I had are the same as you listed in prep.inp. As to tut.run, I also have everything, which are exactly the same as you listed except that there is no item for CELL DATA SELECTED in my file. However, I have the term which is:
| SOLVE . => U, V, P, TE, ED, T,VIS,DEN, | |(STATIC ENTHALPY, CHEMICO-THERMAL FORM SOLVED FOR)| | => INTAKE EXHAUST |
Is it the same as CELL DATA SELECTED?
Thanks again!
Old   November 7, 2000, 08:09
steve
ISOLVE controls what is solved for. CPOST controls what is put out on the PSTT file. Just because you solve for something does not mean necessarily that you want to save it for post-processing. You have the option of not saving things to cut down on disk space required.
No .pstt file Luke Siemens 2 July 24, 2008 09:26
Error with pstt-file, need help! Philipp Daus Siemens 8 June 19, 2007 04:56
.pstt file Andy Siemens 6 March 28, 2006 02:07
Interrupted pstt file furkan Siemens 0 January 19, 2006 08:04
I can not find the pstt file Z.H. Huang Siemens 5 December 6, 2005 09:24
