What variable(s) for facet area on the boundary?
Old   November 20, 2002, 10:08
Default What variable(s) for facet area on the boundary?
Jiaying Xu
Hello, STAR users,
I need to sum up the volumatic flow flux through the outlet boundary, but anyone can tell me what variable(s) or array(s) stand for the facet area on the boundary? Which common block should I quote into bcdefo.f?
I am using an all-tetrahedral mesh. I believe STAR should have stored the info into some variable(s) and I don't need to code the area(s) in my user subroutines.
Many thanks for your help,
Jiaying
Old   November 23, 2002, 01:33
Default Re: What variable(s) for facet area on the boundar
tailor02
under the post menu, you can stor the facet area into a register and store the facet varialbls into another register then then multiply this two register and set the result into the third register
sum up the values in the 1st and last two registers respectively, and execute divide , you can get the average value
how to calculate the area of a boundary in UDF? peter FLUENT 2 May 31, 2021 20:54
Average Facet, Surface Vertex or Area-Weighted Emmanuel FLUENT 3 March 27, 2020 10:55
Facet, Area and Mass Average in Fluent Tushar FLUENT 0 February 5, 2009 23:55
Facet, Area and Mass Average in Fluent Tushar Main CFD Forum 0 February 4, 2009 04:37
cell surface area in boundary.. Chiar FLUENT 0 March 7, 2007 03:53
