January 7, 2004, 08:16 |
Button 'Generate Mesh' doesn't work
I've created a new block and tried to mesh it from the 'Mesh' tab of the 'Create block structured grids' panel. I've set the number of cells for two block edges and pressed the button 'Generate Mesh'. In the output window appeared the following message: "Ececute blocks 95 to 95 by 1 Error - Your increments are not reasonable Error meshing block 95 - Block not meshed No blocks meshed" What increments is it talking about and what could be so unreasonable about them? Thanks in advance, Julie |
January 7, 2004, 09:34 |
Re: Button 'Generate Mesh' doesn't work
In a block you have 3 directions. Lets say you put 10 cells in direction 1. Then you must increment the vertices in direction 2 by at least 11. If you specify/force the vertex increment to be less than 11, then they are not reasonable. If you did not specify the increments yourself, maybe you need to give the block the number of cells on 3 edges (ie all 3 directions).
January 7, 2004, 10:07 |
I'm sorry, can you explain that in some other way. I just don't get what do you mean.
Julie |
January 7, 2004, 18:15 |
A block has 3 directions, I, J, K. You specify the number of cells in each direction - say 10 for I, 5 for J, 2 for K. That means you have 10 cells in the I direction and 11 vertices and so on for J (5 cells, 6 vertices) K (2 cells, 3 vertices). So if you started numbering from 1, the first I row of vertices would be 1-11, the next 12-22, then 23-33...
What the program is complaining about is that it thinks you are trying to force a numbering system that is impossible. If the first row of vertices is numbered 1-11, then the second row can't possibly start at 5. The increment MUST be 11 or greater (make 1 block, set the edges at 10,5,2 turn on vertex plotting and see how it numbers). I just built one myself and it works exactly as described. What I don't know is how you have managed this, but it is likely that you have used the BLKFACTOR command incorrectly (or the gui has messed up). Type HELP BLKF for more information and look at any of the tutorials that use blocks. Look at your echo file to see what the GUI has used for the blkf command. |
Use Gambit to generate 3D mesh ! ! ! | yuanye | FLUENT | 0 | June 3, 2008 22:03 |
Need someone to generate mesh | RA | FLUENT | 7 | May 4, 2007 11:36 |
generate different mesh in CFX_MESH | Eric | CFX | 0 | June 23, 2006 09:09 |
[OpenFOAM] HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview | chan | ParaView | 2 | February 13, 2006 07:37 |
How 2 generate combined mesh? | bogesz | CFX | 0 | April 7, 2004 12:42 |
