Problem in Basics of Star Cd
Old   June 30, 2005, 15:53
Default Problem in Basics of Star Cd
Lalitha
Dear All,
I am trying to generate a 3-D model in STAR CD. I want to construct the geometry of a room ( I dont want to export from Solid works or anything similar). How do I go about it? Thanks in advance.
Lalitha
Old   June 30, 2005, 16:56
Default Re: Problem in Basics of Star Cd
Kevin Till
I would suggest that you go to the help menu on the upper right hand of the screen and go to the tutorials. Go through tutorial number one. After that you should understand how to make simple geometries using coordinate systems.
Old   July 1, 2005, 10:36
Hubert Janocha
I strongly recommand to generate geometries not in StarCD.
Old   July 1, 2005, 11:11
Ben
for any particular reason?
Old   July 1, 2005, 17:08
Hubert Janocha
Yes, in generell the geometry has a better quality, so I save time in repairing it. In my company we use CATIA v4 /v5 as software for machine part design. The IGES interface of CATIA has much problems (lost faces, ...), but the STL-format out of CATIA don't needs much repairing / stiching. With the resurface option in ProAM you will get a high quality surface, even for tet meshing suitable.
If you need better handling of repairing the STL-surface there is a tool called ANSA (from a greek company).
For STL manipulating I use another CFD-software called VECTIS by Ricardo. The preprocessor is nearly perfect in my opinion.
UDF basics PLEASE! Paul FLUENT 4 July 18, 2010 16:23
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
re cfd basics rajesh Main CFD Forum 2 July 16, 2007 13:44
Basics Niklas Nordin FLUENT 0 November 22, 2000 06:20
basics in cfd tonshal Main CFD Forum 7 November 30, 1999 04:04
