Outlet with specified VOLUMETRIC flow rate
Old   June 30, 2005, 22:18
Default Outlet with specified VOLUMETRIC flow rate
sKin
Is it possible to specify a volumetric flow rate at an OUTLET boundary? Since the density for the fluid changes dramatically, mass flow rate cannot reflect the actual case. Thanks!
Old   July 1, 2005, 03:01
Default Re: Outlet with specified VOLUMETRIC flow rate
carno
Negative inlet is the volumetric flow outlet
Old   July 1, 2005, 05:13
som
putting negative velocity makes solution a bit unstable....aint it?
Old   July 1, 2005, 07:36
carno
Sometimes true.
Skin wants volumetric flow const. But why he is doing so is not understood, since there is no conservation of volume law. Even though density changes mass should remain same, whatever may be the volume flow rate. Flow rate should be inforced only on one side. (either inlet or outlet)
Old   July 11, 2005, 21:12
eKin
Thanks carno and som.
I've tried treat the outlet as inlet with negative velocity. Unfortunately, the solver recognised it as a positive velocity (inflow).
Volumetric flow rate litonx OpenFOAM Running, Solving & CFD 0 February 22, 2007 18:05
Constant Volumetric Flow Rate Boundary Condition Hadley Main CFD Forum 0 October 20, 2005 23:13
How to fix an outlet flow rate ? 242VDM242 FLUENT 2 November 24, 2004 08:48
Mass flow rate in outlet Saturn FLUENT 1 October 11, 2004 09:39
setting a volumetric flow rate at a specific place Rage CFX 0 July 25, 2003 16:07
