Problem with Convergence at high flow rates
Old   April 10, 2007, 08:49
Default Problem with Convergence at high flow rates
Syed
Hi
I am simulating flow through a catalytic converter. ITs a 2-D axisymmetric model. I am having convergence problems when using V2F turbulence model. The problem is the solution converges for low flow rates but doesnt converge at high flow rates say 20 m/s. I have tried using MARS, UD and differencing schems.
Can anyone pls help why its not converging at high flow rates.
Thank You Regards Saleem
Old   April 10, 2007, 15:18
Default Re: Problem with Convergence at high flow rates
Pauli
Are you running a transient or steady state analysis?
How are you defining convergence? Does it diverge? Or does it just not reach a steady value?
Have you tried a simpler turbulence model - say standard k-e?
convergence problem with high viscosity Jan CFX 0 February 29, 2008 04:01
Flow rates Sileno Phoenics 9 June 1, 2006 07:09
Flow rates in FLAIR Sileno Phoenics 2 August 2, 2005 10:43
different mass flow rates michael FLUENT 4 February 21, 2005 03:48
Order Criteria and Convergence rates Erich FLUENT 0 August 12, 2004 12:05
