The area of a constrained plane section
Old   January 25, 2013, 04:11
Default The area of a constrained plane section
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I need to determine the area magnitude of two plane sections. I have generated a report for the area magnitude of these two constrained plane sections. STAR CCM gives the area magnitude of one of them. For the other, it shows zero.
What to do to get the area magnitude of other one?
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   February 20, 2013, 11:56
virgy is on a distinguished road
Which report type did you use? For example, with "frontal area" report the problem could be setting the right "view up" and "normal" properties.
virgy is offline   Reply With Quote
Old   February 27, 2013, 06:24
Oliver Lauer
olauer is on a distinguished road
You could create a field function with a constant value 1 and do a surface integral for the constrained plane for this field function
olauer is offline   Reply With Quote
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Cross section and surface area factor Fabiana CFX 0 January 9, 2006 23:51
