Refrigerant flow simulation in capillary tubes
Old   April 8, 2014, 06:40
Default Refrigerant flow simulation in capillary tubes
bhanu1810 is on a distinguished road
Hi
I want to simulate Refrigerant (R 134a) flow in adiabatic capillary tubes.
from Inlet liquid state to outlet mixture state.
1) Which model I should use? (fluid film with evap/cond or vof (evap/cond).
2) How can i define the properties(density, viscosity, conductivity, Cp) of liq and vapor phase with respect to pressure and enthalpy in CCM.
bhanu1810 is offline   Reply With Quote
Old   April 8, 2014, 09:57
me3840 is on a distinguished road
1. The difference between these models is where the phase change is occurring. Where do you expect the change to happen? You should be able to answer this by yourself then.
2. You can specify any property different than constant by going under the material properties. There are plenty of options for specifying polynomials, tables, etc.
me3840 is offline   Reply With Quote
Old   June 24, 2019, 03:03
Vignesh Lakshmanan
ViLaks is on a distinguished road
I need to model r32 flow through adiabatic capillary tubes in Fluent.
My models are:
k-e Turbulence
Mixture multiphase
BC: Pressure Inlet and pressure outlet
Can anyone give some modeling suggestions? It is a compressible flow and I have given variable density (polyunomial) in material properties. Is this correct? I am just not able to get any converged simulation!!!
With Regards
Vignesh
ViLaks is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
Capillary flow?? Jane FLUENT 0 March 1, 2009 21:52
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
