[Sponsors] | |||||
Paul Weller
Rep Power: 13 ![]() |
I am trying to achieve a pulsed mass flow rate of 3.0625E-4 kg/s of air from a thin [500 micron] outlet into atmospheric conditions, over a time period of 20 seconds, with a pulse of 2 seconds, 0.5 secs from the start, with a gap of 6 seconds between pulses.
I believe my physics models are correct; constant density, coupled flow, gas-air, gradients, implicit unsteady, laminar, three dimensional. I have attempted to create a table(time) in excel and saved as .csv, that provides the massflowrate at 0.1 second intervals. I having problems getting this to simulate as it tells me; Bi-Conjugate Gradient Stabilized solver did not converge ! * CFL 50 -> 5... I think the issue may be: the courant number is too high, set at 50 under my mass flow rate boundary condition>physics values>mass flow rate>table(time); Table:Time =Time, Interpolation = Spline, Table:data =Time, Table = Mass Flow Rate[.csv file name] any help would be great thanks |
Rep Power: 26 ![]() |
Check the convective courant number in the channel and make sure your mesh is very fine there. I would bet your timestep is too high.
Paul Weller
Thanks for the advice. i have decreased my courant number from 50 to 5, and also decreased my time step from 0.1 sec to 0.025 secs.
It seems to have corrected the initial error that was happening, but my residuals are still increasing, leading to a floating point exception. is it worth me changing the temporal discretization from 1st to 2nd order, and should i also include a linear courant number ramp? Thanks |
What is the convective courant number in the channel?
Paul Weller
the convective courant number in the channel is very high, around 35000, and increasing with every iteration.
Yeah, that's far too high and probably your problem. You need to resolve that with more cells.
Paul Weller
I have increased the accuracy of the cells in the channel, which has reduced the convective courant number in the middle of the channel, but is still high on the boundary edges. I have included 6 prism layers in the channel that are very small, considering the channel is 500 microns wide.
I have also reduced my time step down to 0.005 seconds. What are your thoughts? Thanks |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 21:33 |
| Mass Flow rate in spray water modeling | Behnam Ghadimi | FLUENT | 0 | June 8, 2013 17:05 |
| Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 16:48 |
| negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 08:17 |
| mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 01:32 |
