November 25, 2015, 00:58 |
Under relaxation factor
Nesrine Bouhrira
Rep Power: 10 |
I'm running a CHT simulation which includes solid-solid conduction then solid-liquid conduction. The flow is laminar. Is it required to use the under relaxation factor ? |
November 25, 2015, 17:43 |
Lane Carasik
Rep Power: 14 |
It is very likely you will need to keep under relaxating even for laminar flow. You can always test it by setting it higher and higher until it won't solve. (It meaning the various applicable relaxation factors that apply to your case.)
November 26, 2015, 08:54 |
Nesrine Bouhrira
Rep Power: 10 |
Thank you for responding.
One more question: Should I activate it from the first iteration and keep it till the last one ? |
November 26, 2015, 12:20 |
Lane Carasik
Rep Power: 14 |
November 26, 2015, 12:30 |
Nesrine Bouhrira
Rep Power: 10 |
I think I got this point. My simulation is not converging due to other problems.
I posted another question earlier do you have an idea how to do it ? I'm posting it again: 'I'm modeling a geometry with CCM+. I have a circular tube in which circulates a hot fluid. The hole tube is covered by a solid layer. So I have solid- solid condction then solid-fluid conduction. I set up the physics for the solid layer which is heated with 38 C but my question is how can I set up the physics for the inner layer of the tube ? Should I set the thermal specification as Temperature ? Because I think that's not correct since the wall of the tube will have variable temperate and will transfer heat to the fluid. Thank you |
Suitable range of relaxation factor for VOF boiling cases? | manupp | STAR-CCM+ | 1 | February 4, 2020 06:07 |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
What's happening to my solution for lower relaxation factor | casesam | OpenFOAM Running, Solving & CFD | 3 | October 22, 2015 01:25 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
Relaxation factor | Moon | Siemens | 1 | June 13, 2003 11:13 |
