Conjugate-Gradient solver did not converge!
Like Tree9Likes
  • 9 Post By ignat
Old   January 26, 2014, 20:40
Question Conjugate-Gradient solver did not converge!
sazrul
sazrul is on a distinguished road
Hi experts,
Currently I am running an Under hood Thermal Management analysis using Star-ccm+ v8.06.005. However, I am facing this error; 'Conjugate-Gradient solver did not converge' while I am trying to run the solution.
Can anyone tell me what does this error means? What should I do to fix it?
Your kind help is highly appreciated .
Regards,
Sazrul
Kuala Lumpur.
sazrul is offline   Reply With Quote
Old   January 29, 2014, 08:19
Alexey
ignat is on a distinguished road
Originally Posted by sazrul View Post
Hi experts,
Regards,
Sazrul
Kuala Lumpur.
It is not serious problem. CG method is used for acceleration pressure solver and this message means only that your task is calculated without acceleration.
You may switch off CG and this message the following way.
Select:
Solver->Segregated Flow->Pressure->AMG Linear Solver->Acceleration method->None
LuckyTran, Venk, SB123 and 6 others like this.
ignat is offline   Reply With Quote
Old   April 18, 2016, 16:43
sulaiman
sms1424 is on a distinguished road
Select:
I am simulating turbulent flow inside a duct, and faced the same issue.
If I ignore the acceleration, I believe that will affect my simulation, Am I right?
Is there a way to fix this issue and get convergence w/o ignoring acceleration?
Thanks!
sms1424 is offline   Reply With Quote
Old   April 19, 2016, 13:36
Alexey
Thanks!
If you ignore the acceleration then that will affect on execution time only. Not solution.
If you don't want to ignore the acceleration then try to make experiments, for example decreas Under-relaxation factor.
Solver->Segregated Flow ->Velocity->Under-relaxation factor
and
Solver->Segregated Flow ->Pressure->Under-relaxation factor
Good luck!
Old   April 19, 2016, 14:02
sulaiman
and
Good luck!
Thank you so much!
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 19:41
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
Can segregated solver be used for compressible flow? Steven-GY ANSYS 0 May 14, 2009 10:37
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Poisson eq and conjugate gradient method Gary Dantinne Main CFD Forum 2 March 19, 1999 00:24
