June 29, 2016, 01:49 |
Volume mesh and Automated mesh
sriram
Rep Power: 9 |
Hi evry1
I am new with CFD and STAR CCM+. When does the volumetric mesh icon must be used.Is it necessary to perform volumetric mesh after Automated mesh is performed.I've used Surface remesher tet prism layer should i perform volumetric mesh aftr these. Thank u |
June 29, 2016, 02:26 |
kevin alun
I suggest taking a few hours and doing some of the meshing tutorials, this program is really easy to use but its good to run some tutorials still,
June 29, 2016, 03:29 |
sriram
Rep Power: 9 |
thank u. i am learning already.Bu can u tel me whats the difference between volumetric mesh and automated mesh?
June 29, 2016, 03:44 |
Rep Power: 10 |
the automated mesh contains the surface mesher and volume mesher. the documentation explains it well
June 29, 2016, 06:39 |
sriram
Rep Power: 9 |
thank u. wil luk into tat.
Consider a problem is running attaining convergence.i stop the iteration make some value change(not much).When start the problem to run , the residual values are attaining a very high peak value and continues to converge.Does this affects the result? |
June 29, 2016, 06:59 |
sriram
Rep Power: 9 |
Can any1 Suggest a basic book to start CFD.i am supposed to work on Star CCM+ now is it better than Fluent??? If so, in what way? Coz i've used fluent a couple of times the results were much quicker than CCM.
Thank u |
June 29, 2016, 09:00 |
#7 | |
Rep Power: 24 |
There are lots of books to 'start' CFD, if you want to learn the basics I would suggest this book: https://www.amazon.com/Introduction-.../dp/0131274988 The question of 'which code is better' is a matter of opinion and experience and varies from application to application. My experience with both codes is that generally STAR-CCM+ is better. Going from CAD files to a volume mesh is almost always faster and far easier, especially with very complicated geometries. Making changes to a model is easier. The solver is not any faster than Fluent's, though, and Fluent's has more options in terms of discretization schemes and coupling schemes. |
June 30, 2016, 07:25 |
sriram
Rep Power: 9 |
Thank you will start from the book
July 1, 2016, 01:49 |
sriram
Rep Power: 9 |
For a flow thru pipe problem
3D,steady,constant density,turbulent,k-epsilon Wall roughness-0.00004m Mesh parameter: Surface remeshr polyhedrl meshr prism layer mesher-(hyperbolic tangent-stretch function,20 no.of prism layers,prism layer Near wall thickness-0.00004m) base size:0.005m i got pressure drop as 2613 pa from simulation when i repeat a new simulation with same parameters,i am not getting the same result Why???? |
July 5, 2016, 05:04 |
Multi roughness wall
sriram
Rep Power: 9 |
Hi evry1
I am working on a problem of flow through pipe(using water medium).Consider i am having a multi roughness wall.(i.e) two dissimilar materials forming a wall hence their roughness values differs.How do i enter the roughness values separately.Is this even possible? Its a turbulent flow problem. |
July 5, 2016, 08:39 |
#11 |
kevin alun
perhaps start a new thread for this question, but not really sure do the two different materials (walls) occupy the same space, than you need to use an eq. value, anyways wall roughness parameter is a model, one can have very long discussions on the meaning of parameter.
if you have a flat surface and these two different materials are next to each other than you need to somehow split the surface to get two boundaries so you can define the roughness for each one. |
July 5, 2016, 23:56 |
got it
#12 |
sriram
Rep Power: 9 |
Thank u...Yes the surfaces are flat and next to each other in a single pipe.I've split the surfaces as split by patch and gave separate roughness values.
July 11, 2016, 07:41 |
new thread
#13 |
sriram
Rep Power: 9 |
how to post a new thread. i cant find it.
July 11, 2016, 07:43 |
#14 |
Rep Power: 10 |
July 11, 2016, 23:55 |
got it
#15 |
sriram
Rep Power: 9 |
June 29, 2016, 08:55 |
#16 | |
Rep Power: 24 |
For a steady-state simulation, no. For a transient run, possibly - depending on what the result is and what you're interested in. |
Solution does not converge (turbocharger) | Jambond | STAR-CCM+ | 22 | October 11, 2016 10:28 |
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD | Chander | CFX | 3 | November 27, 2011 16:24 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
