Volume mesh and Automated mesh
Like Tree1Likes
  • 1 Post By marmot
Old   June 29, 2016, 01:49
Smile Volume mesh and Automated mesh
sriram
sriram9127 is on a distinguished road
Hi evry1
I am new with CFD and STAR CCM+. When does the volumetric mesh icon must be used.Is it necessary to perform volumetric mesh after Automated mesh is performed.I've used
Surface remesher
tet
prism layer
should i perform volumetric mesh aftr these.
Thank u
sriram9127 is offline   Reply With Quote
Old   June 29, 2016, 02:26
kevin alun
marmot is on a distinguished road
I suggest taking a few hours and doing some of the meshing tutorials, this program is really easy to use but its good to run some tutorials still,
Eike likes this.
marmot is offline   Reply With Quote
Old   June 29, 2016, 03:29
sriram
thank u. i am learning already.Bu can u tel me whats the difference between volumetric mesh and automated mesh?
Old   June 29, 2016, 03:44
taillanm is on a distinguished road
the automated mesh contains the surface mesher and volume mesher. the documentation explains it well
taillanm is offline   Reply With Quote
Old   June 29, 2016, 06:39
sriram
thank u. wil luk into tat.
Consider a problem is running attaining convergence.i stop the iteration make some value change(not much).When start the problem to run , the residual values are attaining a very high peak value and continues to converge.Does this affects the result?
Old   June 29, 2016, 06:59
sriram
Can any1 Suggest a basic book to start CFD.i am supposed to work on Star CCM+ now is it better than Fluent??? If so, in what way? Coz i've used fluent a couple of times the results were much quicker than CCM.
Thank u
Old   June 29, 2016, 08:55
me3840 is on a distinguished road
For a steady-state simulation, no. For a transient run, possibly - depending on what the result is and what you're interested in.
me3840 is offline   Reply With Quote
Old   June 29, 2016, 09:00
Thank u
There are lots of books to 'start' CFD, if you want to learn the basics I would suggest this book:
https://www.amazon.com/Introduction-.../dp/0131274988
The question of 'which code is better' is a matter of opinion and experience and varies from application to application. My experience with both codes is that generally STAR-CCM+ is better. Going from CAD files to a volume mesh is almost always faster and far easier, especially with very complicated geometries. Making changes to a model is easier. The solver is not any faster than Fluent's, though, and Fluent's has more options in terms of discretization schemes and coupling schemes.
Old   June 30, 2016, 07:25
sriram
Thank you will start from the book
Old   July 1, 2016, 01:49
sriram
For a flow thru pipe problem
3D,steady,constant density,turbulent,k-epsilon
Wall roughness-0.00004m
Mesh parameter:
Surface remeshr
polyhedrl meshr
prism layer mesher-(hyperbolic tangent-stretch function,20 no.of prism layers,prism layer Near wall thickness-0.00004m)
base size:0.005m
i got pressure drop as 2613 pa from simulation
when i repeat a new simulation with same parameters,i am not getting the same result
Why????
Old   July 5, 2016, 05:04
Cool Multi roughness wall
  #11
sriram
Hi evry1
I am working on a problem of flow through pipe(using water medium).Consider i am having a multi roughness wall.(i.e) two dissimilar materials forming a wall hence their roughness values differs.How do i enter the roughness values separately.Is this even possible?
Its a turbulent flow problem.
Old   July 5, 2016, 08:39
kevin alun
perhaps start a new thread for this question, but not really sure do the two different materials (walls) occupy the same space, than you need to use an eq. value, anyways wall roughness parameter is a model, one can have very long discussions on the meaning of parameter.
if you have a flat surface and these two different materials are next to each other than you need to somehow split the surface to get two boundaries so you can define the roughness for each one.
Old   July 5, 2016, 23:56
Smile got it
  #13
sriram
Thank u...Yes the surfaces are flat and next to each other in a single pipe.I've split the surfaces as split by patch and gave separate roughness values.
Old   July 11, 2016, 07:41
Default new thread
  #14
sriram
how to post a new thread. i cant find it.
Old   July 11, 2016, 07:43
home > forums > star ccm + : new thread
Old   July 11, 2016, 23:55
Thumbs up got it
  #16
sriram
thank you..found it
Solution does not converge (turbocharger) Jambond STAR-CCM+ 22 October 11, 2016 10:28
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD Chander CFX 3 November 27, 2011 16:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
