September 2, 2016, 01:13 |
y+ value ~1 question
Edward Kraft
Rep Power: 11 |
So the wall function I'm using requires a y+ value to be as close to 1 as possible. If my max y+ after simulation is around .02, does that change my results significantly than if my max y+ was lets say 0.9? Does the closer max y+ is to 1, the better the results, or as long as my max y+ is less than one, I'm good to go? Thank you.
September 7, 2016, 10:07 |
Xiaosong Zhang
Rep Power: 11 |
Your results will not be accurate considering your y+ is .02. You should make it around 1 as possible as you can. Y+ is a function describing the distance of first node from the wall. The y+ value is a non-dimensional distance (based on local cell fluid velocity) from the wall to the first mesh node. To ensure that y+ values are not so large that the first node falls outside the boundary layer region. If this happens, then the Wall Functions used by our turbulence model may incorrectly calculate the flow properties at this first calculation point which will introduce errors into our pressure drop and velocity results.In addition to the concern about having a mesh with y+ values that are too large, you need to be aware that if the y+ value is too low then the first calculation point will be placed in the viscous sublayer flow region and the Wall Functions will also be outside their validity. To be short just make it around 1.
September 8, 2016, 07:57 |
Gajendra Gulgulia
Hi Edward,
as far as I remember, the y+ values should be selected based on the flow regime. If your flow is laminar throughout, then you must make sure that the y+ values lies within 1 to 10 and if the flow is turbulent, then it should be in the range of 10 to 300. You need to tune the mesh accordingly for each case. In each case you can select the All Wall model for turbulent schemes when you select the models. This is a hybrid model that takes care of the near wall flow resolution. Thanks |
September 8, 2016, 19:33 |
#4 | ||
Lane Carasik
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 04:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
