September 17, 2016, 12:33 |
CPU utilization
say
Rep Power: 10 |
Hello.
I am having trouble making use of all the processors available on my workstation. The workstation has 2 sockets, 20 cores and 40 logical processors, running on Windows 10 Enterprise. Now, I run Star CCM by loading the simulation on Parallel on Local Host, Compute Processes : 40, but when I check performance as it is running, only 20 CPUs from node 0 run at max capacity, while the other 20 CPUs from node 1 are barely used(under 5%). Should I be using Microsoft Job Scheduler or some setting to make use of CPUs in node 1? Thank you in advance. Seyong. Last edited by shammon; September 17, 2016 at 12:34. Reason: tags |
September 18, 2016, 14:26 |
#2 | |
Lane Carasik
Additionally, contacting CD-Adapco support may help you get an answer. |
September 22, 2016, 20:20 |
Rep Power: 24 |
Try using a different MPI. I believe there is a limitation for the default MPI for newer Intel silicon with high core counts.
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
