Solver for isochoric process
Old   December 13, 2016, 03:03
Default Solver for isochoric process
simulant1 is on a distinguished road
I am simulating an isochoric process:
- Closed Cube (4 wall boundaries, as I am doing a 2D-simulation)
- Gas (Air) filled
- Heated by the walls from 300 K to 400 K
- No velocity profile, only natural convection
For this case, the volume and the mass is constant. Therefore, the average density in the cube is constant. Because of the Ideal Gas Law, the pressure should rise with the temperature rise of the gas. But in my simulation, only the density changes (which is physically total wrong), but the pressure stays almost constant. Also, if I change the thermal conductivity of the gas, the value of the pressure at the end of the simulation is completely different, which is totally wrong. Thermal conductivity only affects, "how fast" heat is transferred trough the gas, but does not affect the pressure level at the end of the simulation.
This all happened, while I was using the Coupled Solver. Yesterday I switched to the Segregated Solver and now everything is fine. All of the problems from above are fixed and the pressure rise is corresponding to p2/p1 = T2/T1 (Ideal Gas law for an isochoric process), while the average density in the volume is constant.
Did I find a bug in the coupled solver? Because I think, the different solvers only change the way, how the equations are solved, but should not effect the results on the whole (especially not in that extreme way, it does here).
Best regards
simulant1 is offline   Reply With Quote
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Some notes on Creational Process of an OpenFOAM solver jaswi OpenFOAM Running, Solving & CFD 1 August 30, 2010 11:49
Automating Solver Process KUAERO Fluent UDF and Scheme Programming 3 July 24, 2010 04:16
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
