April 29, 2017, 05:49 |
Table initialization
Muh
Rep Power: 10 |
I want to initialize a new simulation with the solution from an old simulation. I do this by extracting data in table(x,y,z) format which then is set in Continua. However, the simulation crashes and writes terminated in the terminal windows. This might be due to large csv file. I need to use the old solution to initialize my new simulation. Does anyone have advice on how to proceed from here. Best regards/ |
April 29, 2017, 07:00 |
Muh
Rep Power: 10 |
So typically CFD Online - Answers comes 4 months later. Nice forum
April 29, 2017, 07:41 |
Muh
Rep Power: 10 |
I solved it!
You should get rid of this unhelpful forum. / |
April 29, 2017, 19:29 |
Lane Carasik
Rep Power: 14 |
May 2, 2017, 09:35 |
Rep Power: 24 |
Anyway, since the OP doesn't wish to enlighten the useless forum with his solution, let me just say:
Do not use tables for interpolation like this, especially for large cases. This is very inefficient and if your case is big enough you will easily swap your hardware. Instead use a CCM file and map your data using a volume data mapper. |
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
Full Multigrid Initialization | Mr.Goodcat | FLUENT | 0 | March 17, 2016 06:43 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
Installing OpenFoam on windows 7-64 | Dadou | OpenFOAM Installation | 10 | February 11, 2014 16:20 |
Table Manipulation | furkan | Siemens | 0 | April 4, 2006 10:23 |
