From surfaces to bodies
Old   January 10, 2020, 03:48
Default From surfaces to bodies
Emanuele
Prothean is on a distinguished road
Goodmorning everyone,
I am a newbie in the CFD analysis and a new user of Star CCM+
For my master thesis I have to study the aerodynamical performances of a car, and i imported it as an x_t file on the software but i can't convert sheed bodies to solid bodies; I have tried with extrustions, extended surface and many other ways including the surface wrapper (i have read the other thread with a similar problem with the boat, but that it didn't help me).
Can't find any solution in Steve Portal too, someone could help me please?
Here's a picture one of the many components i have to convert from sheet to solid
Prothean is offline   Reply With Quote
Old   January 12, 2020, 11:16
me3840 is on a distinguished road
Well for that particular part all you have to do is click on the green edges and select fill holes in the surface repair menu. I suggest you go through the surface repair tutorials.
me3840 is offline   Reply With Quote
Old   January 12, 2020, 11:42
Emanuele
Hi me3840 and thank you for your reply,
what i am really intended to do is to ad a little bit of thickness on the shoulder of my tyre, and the "fill holes" options would close the whole sides of the wheel
Old   January 12, 2020, 11:57
If the geometry is drawn wrong then your best path forward is to go back to your CAD package and fix it.
Old   January 13, 2020, 01:15
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
You can do somewhat basic modifications in CCM as well. Select the surfaces you want to translate in some specific direction and then in surface repair, Go into Global>>Translate or inflate.
Remember the capabilities in this section are quite limited, so if you can go0d knowledge of CAD package, it is better to do it in there.
ashokac7 is offline   Reply With Quote
Old   January 13, 2020, 10:34
Emanuele
I think it's better going back to my CAD software then, thanks everybody!
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 14:31
[DesignModeler] Find face normals to selected faces Pallati ANSYS Meshing & Geometry 1 July 26, 2017 11:04
NURBS surfaces on a wing frossi CFX 5 February 5, 2017 15:27
[Other] how to define complex/irregular bodies in the mesher Ema40 OpenFOAM Meshing & Mesh Conversion 4 March 9, 2016 16:04
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
