How to simulate a pile of static particles on the flow channel
Like Tree2Likes
  • 2 Post By calmdown911
Old   December 12, 2017, 16:50
Default How to simulate a pile of static particles on the flow channel
calmdown911 is on a distinguished road
I came across a difficult problem. I'm trying to do this simulation using STAR-CCM+:
a static pile of particles is rested on a flow channel and the fluid flow will flow across the pile of particle. I'm trying to simulate this process to study the particle movement.
How to create the pile of particles on the flow channel that is initially static?
calmdown911 is offline   Reply With Quote
Old   December 13, 2017, 06:40
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
I don't know if it works for sure or not. But I can suggest one method. Create a DEM particles to make the pile. For this create a region where you need a pile of particles an then make it's wall non-penetrable for DEM particles. Calculate for how many particles do you want. Freeze flow solver and all except DEM. The n run (DEM only) for definite time based on you calculation for pile. Then unfreeze flow solver make wall penetrable and run the simulation. Hope this works, I am sorry if it doesn't .
ashokac7 is offline   Reply With Quote
Old   December 13, 2017, 08:45
Hi, ashokac7,
Thank you so much for your reply! Your idea is valuable to me.
Just a few more questions:
1. How to freeze all the solvers than DEM?
2. Whether the wall be penetrable or not is set in boundary conditions for DEM particles right? What if I use derived parts for injector?
Thank you so much for your help!
Old   December 14, 2017, 01:16
ashokac7's Avatar
Ashok Chaudhari
Originally Posted by calmdown911 View Post
Hi, ashokac7,
1. How to freeze all the solvers than DEM? Expand the solver node, click on Segregated flow and then in properties panel blow, check the Freeze flow
2. Whether the wall be penetrable or not is set in boundary conditions for DEM particles right? Yes What if I use derived parts for injector? yes you can, that's your choice
Hope this works. But I can not say for sure. See answers above in RED
Old   December 14, 2017, 09:57
Thank you so much for your help! Hope it work!
ashokac7 and synuk75 like this.
How to manage the pressure term in fixed mass flow rate based channel flow simulation sjwon1991 Main CFD Forum 5 July 10, 2017 07:21
Enabling Open Channel Flow Sub-Model in Mixture model cod213 FLUENT 0 January 10, 2017 13:40
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel HectorRedal Main CFD Forum 1 December 18, 2016 11:41
Using k-omega SST to simulate simple channel flow MaLa OpenFOAM Running, Solving & CFD 15 June 19, 2014 04:48
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
