May 21, 2022, 04:27 |
Volume flow rate as the boundary condition
Zhang Yan
Rep Power: 4 |
Hello everyone!
I faced some problems when using Star-CCM+. (1) In engineering field, volume flow rate is more commonly used than mass flow rate. Therefore, I would like to ask how to set up volume flow rate inlet in Star-CCM+. If there is no direct way to set volume flow rate, is there an alternative method? (2) The outlet is usually set as pressure-outlet. I want to ask if continuity can be guaranteed (I mean the inlet and outlet flow rates are equal). I would appreciate it if someone could help me. Thank you! |
May 23, 2022, 01:50 |
Lucky
Rep Power: 66 |
Volumetric flowrates are specified using velocity inlets and very rarely velocity "outlets."
You are solving a momentum balance equation and a mass continuity equation, so your result had better meet continuity criteria or you have another problem. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 03:53 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
