May 22, 2018, 05:40 |
Dem
tuvia milshtein
Rep Power: 11 |
Hi
Im using the DEM and it works good. I manage to inject particles and the sum of them increases. Also, I autosave the results every period of iterations. When I try to use a file that I save and continue the run the injector does not work and the number of the particles remains constant !! Any idea ? Thanks |
December 10, 2018, 16:48 |
DEM with Jet
D Huang
Rep Power: 7 |
I have modeled a DEM that the particles are injected from the bottom of the cylinder.
I would like to check the particle behavior if I apply the jets at the wall of the cylinder. I don't know to apply the jet in this already established DEM model, or do I need other tools. I appreciated your help. Thanks, Dawn |
Two-Way coupled DEM with heat transfer - Which is good?:+ LIGGHTS/OpenFOAM/CFDEM/<??> | yesaswi92 | Main CFD Forum | 1 | November 27, 2023 04:49 |
Dem v.s dpm? | Amir1 | Main CFD Forum | 1 | November 3, 2019 09:52 |
problem with controling the motion of DEM parcels | akshaybagi | STAR-CCM+ | 0 | April 1, 2017 23:33 |
DEM particle interactions with lagrangian phase | seraph333 | Siemens | 1 | December 2, 2011 19:43 |
DEM for erosion | alan81 | STAR-CCM+ | 4 | September 5, 2011 10:47 |
