Extract volume
Like Tree5Likes
  • 1 Post By Maddin
  • 2 Post By me3840
  • 1 Post By Maddin
  • 1 Post By pavko718
Old   November 4, 2018, 03:28
Default Extract volume
Nadaaaa22 is on a distinguished road
I’m new in Star-CCM+, I did a CAD and I imported it in the star-CCM+, it is a complicated geometry with a lot of cavities in irregular shapes how can I extract/subtract volume, I want to add fluid through these cavities but I don’t know what is the best way? Do I need to add a domain or there is another way?.
A similar shape to mine is attached.
Thank you
Nadaaaa22 is offline   Reply With Quote
Old   November 4, 2018, 08:21
Maddin is on a distinguished road
Can you show/explain a little bit more?
Most operations you can do on the surface level. Remeshing with protection of the geometry (feature lines!) supports you.
Nadaaaa22 likes this.
Maddin is offline   Reply With Quote
Old   November 4, 2018, 14:54
My problem is somehow similar to the picture attached. I have the solid but I'm facing a problem how can I add the fluid?
Thank for your replay
Old   November 4, 2018, 14:59
me3840 is on a distinguished road
If you have the solid body of that geometry then you just need to make a volume which encompasses it and do a boolean subtract.
Considering the complexity of that body I suggest doing this in a CAD package instead of STAR-CCM+.
Maddin and Nadaaaa22 like this.
me3840 is offline   Reply With Quote
Old   November 4, 2018, 17:58
I think to add a body around is possible with CCM to become a negative.
But I also think direct in CAD is faster.
Old   November 5, 2018, 16:19
PK
pavko718 is on a distinguished road
There are multiple ways to get the fluid volume. You can get it via subtraction in the original CAD package, as others have already mentioned. You can also do the same subtraction in STAR-CCM+, either at the CAD level (3D CAD) or using operations in the parts branch of the tree. This last method support CAD and surface level boolean operations. Lastly, you can use the Extract Volume operation in the parts branch to get the volume.
If your lettice does not contactact any other wall in your domain, you can simply make a box and combine it with your part, no extraction necessary. Then mesh this new part.
pavko718 is offline   Reply With Quote
Old   November 7, 2018, 14:57
Thank you all for your help.
Old   November 7, 2018, 15:03
Sorry for this question what is the CAD package is it different from the 3-D CAD thank you.
Old   November 7, 2018, 17:46
"the CAD package" is whatever CAD software you are using (Catia, NX, Solidworks, etc). 3D-CAD is STAR-CCM+'s internal CAD software. It is pretty good for a CFD code, but it will struggle with anything really big or complex.
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 15:02
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
