March 15, 2019, 07:24 |
Flow of a gas mixture through a membrane
Rep Power: 14 |
Hello together,
I just want to setup a little test case, which is shown in the attached picture Phase 1 and Phase 2 are both gaseous but the membrane allows Phase 2 to crosse easier than Phase 1. So it would be necessary to define a permeability of the membrane which is different for phase 1 and 2. The membrane is very thin. This is the reason why it would be sufficient to use an interface with the above explained properties. At the moment I canīt find a tutorial or anything else to help me with the start. Would be the eulerian multiphase solver the best choice for this problem? Where can I define the properties of the interface which should behave like the membrane? Thanks a lot for your help |
March 18, 2019, 01:28 |
Rep Power: 14 |
Does nobody have an idea? I am appreciate every little hint
Thanks! |
Modeling the gas flow through the packed bed of DEM particles | Legat | STAR-CCM+ | 6 | January 17, 2024 08:58 |
gas solid flow in circulating fluidized bed with different gas velocity | kongl1986 | FLUENT | 2 | April 5, 2012 22:23 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
