Notorious Difference in Tdr Residual for two Simulations of the same Model |
April 24, 2019, 03:51 |
Rod Lamar
Rep Power: 7 |
Good Day everybody,
As the title states, I have come across a massive difference in the values for Tdr when I run a simulation on a very same model. Do I run it as it is, the solution converges nicely, but I have reverse flow for 500 faces at the outlet. Do I happen to extrude the inlet and outlet eight times the inlet/outlet diameter (as suggested by the steve portal), I do not have the reverse flow problem anymore, yet Tdr asymptotically approaches 0.1. Has the simulation for the extruded model converged even though Tdr is not under 10^-3? Any suggestions in this reguard would be very welcomed |
April 24, 2019, 19:52 |
Steve
Rep Power: 8 |
Hi.
Did you show the residual plot which is normalized? In STAR-CCM+ default setting of residual is normalized.. You should turn off normalized option and recheck residual. Because of extruded mesh, the initial normalized value can be changed |
April 25, 2019, 03:31 |
Rod Lamar
Rep Power: 7 |
Yes, residuals are normalized in the "Auto" mode with maximum of 5000 plot samples.
In your opinion, I should switch the normalization off and see if the amount by which they vary is sufficiently small? Thanks |
April 25, 2019, 04:30 |
Steve
Rep Power: 8 |
Try it
In CCM+ normalize using first 5 step..(default) If your residual still have too big gap, you should check BC and IC |
April 25, 2019, 10:09 |
Rod Lamar
Rep Power: 7 |
Yes, it worked like a charm! Now all residuals are at 5e-6 with the exception of Tdr that is at 5e-3. Assuming the convergence is a safe bet here. Thanks
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
