Streamlines vs moving reference frame
Like Tree1Likes
  • 1 Post By fluid23
Old   June 21, 2019, 06:40
Default Streamlines vs moving reference frame
Lucky Luka is on a distinguished road
Hi all
I have 3 regions in my axial fan simulation model.
I used a moving reference plane for my rotating fan. Air is represented in the region of the fan (the middle region of the 3 present).
I don't like the way streamlines appear in the fan region though.
I've been told that there is a way to solve this issue but I don't know how to do that.
Can anyone help me?
Cheers
Lucky Luka is offline   Reply With Quote
Old   June 21, 2019, 09:54
Matt
fluid23 is on a distinguished road
You will have to be more specific about what you want to change.
fluid23 is offline   Reply With Quote
Old   June 21, 2019, 10:04
Hi
I just want to see streamlines inside the fan.
The ones that are present right now are those one of the two adjacent regions.
Is it possible?
Cheers
Old   June 21, 2019, 10:06
Matt
Perhaps I misunderstand, but I see streamlines inside the fan region. Are they not what you expected?
Old   June 21, 2019, 10:07
Matt
Can you take a screencapture of your derived parts setup? (prtscn would be prefered over a photo, btw.)
Old   June 21, 2019, 10:08
I expected to see them more in circles than what I got.
I thought it was due to the moving reference frame solution I used for the fan the fact that they barely develop inside the fan region.
Old   June 21, 2019, 10:14
Matt
I would expect to see them change direction, but not necessarily swirl around within the fan region. The streamlines coming out of the back have obvious swirl.
Now that being said, you know what you are modeling better than I. If you have another reference or something you are comparing to that is similar and shows this behavior, then there might be something that needs to change.
Old   June 21, 2019, 10:27
Matt
It does look like not all your streamlines are showing up on the other side. You might try adjusting the max propagation/steps in derived part > streamline> integrator.
Lucky Luka likes this.
Old   June 26, 2019, 08:51
Joern Beilke
JBeilke is on a distinguished road
The trick is to create a new vector field function for the velocity which takes the absolure velocity in the fixed region and the relative velocity for the impeller.
JBeilke is offline   Reply With Quote
Single moving reference frame vs Multiple reference frame for Wind Turbine CFD mrswordf1sh FLUENT 4 January 25, 2020 08:43
interFoam with moving reference frame Martin_K_lalelu OpenFOAM Running, Solving & CFD 0 November 4, 2014 02:41
moving mesh vs moving reference frame nikolaous FLUENT 0 August 1, 2012 18:46
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
