November 20, 2020, 09:44 |
Ventilation system
OK
Rep Power: 5 |
Hi every one
How can I make a cylinder that inside a box work as jet fan (ventilation system), So I need the jet fan suck the air from the box and back it to the box with different kinetic energy . I am using star ccm+ Thank you. |
November 21, 2020, 09:29 |
#2 | |
Aleksandr
Rep Power: 5 |
region.png |
November 21, 2020, 11:28 |
OK
Rep Power: 5 |
Thanks.... but I need to make the same air that inter the box move forward the cylinder and thrust it again to the box .... I make it by change the interface between the cylinder and the box to Fan interface .... is this correct ?
November 21, 2020, 17:43 |
Aleksandr
Rep Power: 5 |
Whether it is correct or not depends on how the problem is solved. You should have posted a sketch, at least.
November 22, 2020, 04:35 |
OK
Rep Power: 5 |
Your photo is way is good but it doesn't work with me I need both of the cylinders in the photo below work as jet fans. I use the fan interface to do this is there any other way to make it ?
Thank you . |
November 26, 2020, 14:35 |
OK
Rep Power: 5 |
November 26, 2020, 14:57 |
OK
Rep Power: 5 |
or please attach your project that you took that picture from
I will appreciate that . |
November 26, 2020, 15:46 |
#8 | |
Chaotic Water
Rep Power: 17 |
- "What Are Interfaces?" - p331; - "Interfaces Overview" - p2157; - "Fans and Blowers" - p3887. I'm pretty sure - the community will appreciate that and welcome the qualified engineer and software user who is trying hard to learn. Not the tutorial/example beggar. |
November 26, 2020, 17:49 |
#9 |
OK
Rep Power: 5 |
And I am sure that if you keep your chatter for your self the community will appreciate that to.
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 0 | June 22, 2016 08:26 |
Problem with exporting solution data concerning the coordinate System | elbi_ente | Structural Mechanics | 0 | October 9, 2015 01:49 |
Coupling inlet and outlets massfluxes in an enclosed circulation system | NielsB | Main CFD Forum | 1 | October 8, 2015 05:26 |
Is it suitable for building ventilation system simulation? | llrr | Autodesk Simulation CFD | 3 | March 1, 2012 11:53 |
Need ideas-fuel delivery system | Jan | Fidelity CFD | 0 | October 9, 2006 04:30 |
