December 1, 2020, 21:28 |
Dynamic Mooring With Overset Mesh
Aldias Bahatmaka
Rep Power: 10 |
Hello everyone,
Is there any body has experience for simulation of dynamic mooring line with overset mesh in star ccm+? Actually for overset mesh is having no problem but when i running the simulation always stopped due to the body was penetrating the bottom region (wall boundary) I’m curious about the relation between wall contact with overset mesh. My simulation conditions are the boat has been moored by the chain to the ground (bottom wall) By using implicit unsteady, and overset mesh method with DFBI. If you guys have experience could share to me, I’ll appreciate to you. Best regards Aldi |
December 2, 2020, 20:21 |
#2 | |
Aleksandr
Rep Power: 5 |
December 2, 2020, 20:40 |
Aldias Bahatmaka
Rep Power: 10 |
December 30, 2020, 09:50 |
#4 | |
Lefteris
Rep Power: 15 |
I had a similar simulation crashing but in that case I changed some properties of the catenary model (honesty, can't remember which one) and the simulation ran fine after that.
Lefteris |
January 4, 2021, 21:54 |
Wall Contact
#5 | |
Aldias Bahatmaka
Rep Power: 10 |
from the out file (error messages) : "Zero aceceptor cells in region "concrete_L5". when I checked in the scalar scene, the concrete was hit and penetrating the wall boundary. (it can be seen in picture), and I did the body coupling in DFBI for contact inputs, I selected the wall (bottom boundary) for being contact surface. But still hit and penetrating the bottom wall. what should I do? need your suggestions. Thanks so much, Regards, Aldi |
March 31, 2024, 08:45 |
#6 | |
Runxin Luo
Rep Power: 4 |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 15:08 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour | Caster_Troy | FLUENT | 1 | December 7, 2017 06:19 |
Overset MESH problem DFBI 6DOF | Ale85 | STAR-CCM+ | 0 | October 1, 2013 12:25 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
