January 19, 2021, 17:09 |
Prismatic layer issue
Enrico Aloisi Nardi
Hello everybody, I'm currently studying air flow around a building but I seem to have some issues regarding the prismatic layer generation, especially in the region between the building and the floor (picture attached). Both of them are defined as walls in my region and I haven't declared any contact between them. Since it's my first post here in the forum, let me know if I missed some detail useful to the problem. Thanks in advance, any help is appreciated.
January 20, 2021, 03:49 |
Regarding your mesh, i guess this a problem of boundary layer mesh settings : try to set Minimum Thickness Percentage and Layer Reduction Percentage respectively to 0.01 and 0 (minimum values) in your Prism Layer Mesher properties. Clement |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 10:56 |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 04:26 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
