February 1, 2021, 05:28 |
Modelling a filter as porous media
Rep Power: 5 |
Hello everyone,
i am trying to model a filter using porous media in STAR-CCM+. I want two things to get done with the porous media: 1. pressure drop via the filter 2. flow-straightening, the flow above the filter is turbulent, the flow below the filter after crossing the filter has to be laminar. Does anyone have recommendations how to model this? I tried via porous Region first but had the Problem that no flow-straightening and no pressure drop occured; the flow looked Always the same regardless the values for porosity and tortuosity, it Always just looked like a "normal fluid Region". I also tried with porous media model but star automatically changed my interfaces to baffle and i couldnt Change them back to internal, and due to baffle interfaces not working with porous media model i couldnt manage that way neither. Did someone model a filter and is able to give me some recommendations on how to set up and what values and Settings have to be taken? Thanks a lot in Advance!!! |
February 1, 2021, 20:18 |
Chaotic Water
Rep Power: 17 |
You can learn more about modeling porous media if you spend some time on reading the manual - pp 3819 «Examples of Setting Porous Resistance Properties» for example.
filter, porous media, porous media model, porous region |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
2Phase flow simulation in Porous Media Ansys Fluent | Yaqub | FLUENT | 0 | June 22, 2017 03:46 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
modelling porous media | Mine | FLUENT | 3 | May 19, 2014 14:35 |
Porous media modelling in ANsys | dreamlifter747 | ANSYS | 0 | September 13, 2013 10:29 |
