Surface intersect itself error message while doing volume meshing
Old   June 21, 2022, 09:34
Exclamation Surface intersect itself error message while doing volume meshing
Kerala
akshaymohanvp is on a distinguished road
I was trying to volume mesh an assembly. Before that itself using surface repair option , I had made sure that there were no errors in the geometry. Still, when I am trying to do volume meshing ,error message "the surface intersect itself " is showing . The volume mesh is getting failed. What should I do to rectify this?
akshaymohanvp is offline   Reply With Quote
Old   June 21, 2022, 23:00
cwl
Chaotic Water
cwl is on a distinguished road
Right-click your parts and select Repair Surface - to check where that happens.
cwl is offline   Reply With Quote
Old   June 22, 2022, 03:41
Kerala
I had already cheched in surface repair. There is zero error showing]
Old   June 22, 2022, 03:51
cwl
Chaotic Water
Did you check the tessalated (like "geometry") surface - or the remeshed (by Automatic Mesher) surface?
Old   June 22, 2022, 12:57
Kerala
Tessalated surface
Old   June 22, 2022, 13:10
cwl
Chaotic Water
Check the remeshed surface - it is used during construction of the volume mesh.
star ccm +geometry, star ccm+, star ccm+ error
multiphaseEulerFoam FOAM FATAL IO ERROR qutadah.r OpenFOAM Running, Solving & CFD 11 December 10, 2021 20:18
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[ICEM] Meshing the Fluid Volume of a Fibrous Membrane/Media--Help with errors/settings? ANT ANSYS Meshing & Geometry 4 July 10, 2013 00:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Volume 1 has invalid topology for mapped brick meshing georgewar ANSYS 0 July 24, 2011 16:02
