Calculate Thermal Resistivity
Old   August 23, 2022, 11:03
Default Calculate Thermal Resistivity
Marc Ricart
cramr5 is on a distinguished road
I am trying to size a cooling interface and decide if we need liquid or air cooling and for that I would like to extract a Thermal Resistivity value from the cold plate.
Right now I am running a simulation with a specified negative heat flux (W/m2) on the cold plate surface but most manufacturers size their cooling devices using the Thermal Resistance (K/W or ºC/W) and would be useful to get that number.
I've seen that from Reports you can select the Function "Thermal Resistance" but I cannot manage to make it show anything. I don't know which type of Report I should use.
Thanks a lot in advance for your help.
cramr5 is offline   Reply With Quote
Old   August 23, 2022, 20:08
cwl
Chaotic Water
cwl is on a distinguished road
Why not just calculate thermal resistance of the plate as R = δ/λ?
cwl is offline   Reply With Quote
Old   February 22, 2023, 22:31
Zu Mailand
beginner2023 is on a distinguished road
I wonder whether the formulation is correct when you have the information of temperature at the bottom and top surfaces
Thanks
beginner2023 is offline   Reply With Quote
Old   February 23, 2023, 07:31
cwl
Chaotic Water
What do you mean?
Old   February 23, 2023, 07:59
Zu Mailand
I meant how about the formulation
R = \Delta T / \Delta_Q
This formulation can be used for calculating the thermal resistance of package die after the thermal simulation is finished, right?
Thanks
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 18:04
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 17:26
CAN i calculate thermal stress in CFX??? prayskyer CFX 3 July 5, 2006 20:05
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
