Home > Forums > Software User Forums > Siemens > STAR-CD
relative velocity for a radial turbine wheel
Old   December 15, 2011, 04:45
Default relative velocity for a radial turbine wheel
Niklas Winkler
nikwin is on a distinguished road
I have a set of transient data for a radial turbine including the event file (.evn) and would like to compute the relative velocities in the wheel. The wheel rotation is simulated with the sliding mesh technique. Could anyone please give me a hint of how to or point me to a relevant tutorial.
Thanks
/NW
nikwin is offline   Reply With Quote
Old   December 15, 2011, 07:20
Joern Beilke
JBeilke is on a distinguished road
Use the "reframe" command.
JBeilke is offline   Reply With Quote
Old   December 15, 2011, 07:24
Niklas Winkler
Thanks for your quick reply!
I've tried the following, reframe,2,local,(OMEGA), used the second coordinate system with the following command, csys,2 and then tried to extract the data again. However, it subtracts the data from the entire field and not just from the wheel. Do you know how I can specify a part of the field to get relative velocities at the wheel only?
All the Best
/NW
Old   December 15, 2011, 08:48
Joern Beilke
There are 3 possibilities for using the command.
  • refr stat
  • refr compu
  • refr loca icsys omega
Just try what gives the best results.
I don't see an easy solution for the other problem right now.
Old   December 15, 2011, 11:54
Robert
RobertB is on a distinguished road
I would think that you should be able to get there from here with OPERATE and CHANGE
If you use PSYS to set the basic system for post processing
Then you can
Getc,all
to get the vectors in the axis of the rotor
Oper getc x axis_syst 5
Oper smult omega 5 5
Cset news all non rotating cells
change cset 0 0 0.0 0.0 5
oper subt 2 5 2
Oper unrotate
Not sure if this does exactly what you want but some combination of the above commands or similar should get you there from here
RobertB is offline   Reply With Quote
Old   December 22, 2011, 10:33
Niklas Winkler
Thank you! The command oper,refr,local,(coord syst),(omega) did the trick!
All the Best
/NW
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
how to derive relative velocity in MRFSimpleFoam? renyun0511 OpenFOAM Running, Solving & CFD 24 June 8, 2017 02:23
relative velocity Zaktatir CFX 34 June 23, 2010 09:28
relative velocity postprocessing Salman Main CFD Forum 8 July 27, 2009 09:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
